Creates a PVLAN framework with the specified name.
| name | Specifies a name for the new PVLAN. |
| vr_name | Specifies the VR in which the PVLAN is created. |
N/A.
The PVLAN is a framework that links network and subscriber VLANs; it is not an actual VLAN.
A private VLAN name must begin with an alphabetical character and may contain alphanumeric characters and underscores ( _ ), but it cannot contain spaces. The maximum allowed length for a name is 32 characters. For private VLAN naming guidelines and a list of reserved names, see Object Names in the Switch Engine v33.1.1 User Guide .
If no VR is specified, the PVLAN is created in the default VR context.
The following example creates a PVLAN named "companyx":
create private-vlan companyx
This command is available on all platforms that support the Private VLAN feature. For features and the platforms that support them, see the Switch Engine v33.1.1 Licensing Guide document.
